[Qgis-developer] Processing - current status of "in-between" layers	while running models
    kimaidou
    kimaidou at gmail.com
    Mon May 16 05:28:39 PDT 2016
Hi all !
I was wondering what was the current status for layers created as ouput of
algs and used as input in child algs ? I remember reading some new feature
in this area, but I cannot remember what was the conclusion. Is there some
options allowing to do the following :
* use memory layers for all intermediate layers -> could be very fast, but
there should be some way to prevent bloating the computer if the input data
is too big ( the user would prefer to avoid memory layer if it leads to
swap )
* use a unique spatialite database to store the intermediate layers. In
this case
  - create automatically spatial indexes ( it is fast )
  - use rasterlite to store raster layers ? Or use a kind of foreign data
wrapper for sqlite ?
* For both options, obviously keep the long field names along the process,
and the complex data types ( and do not restrict to the 4 datatypes
available in DBF )
* I am aware that the use of Grass or other rich algs provider (Saga,
Taudem) can lead to using their internal format. What are the possibilities
and limits in this case ? For example for vector, Grass needs to import the
data, but what about for raster like GeoTiffs ?
Thanks in advance for your sharing your opinions and knowledge on this.
Regards,
Michaƫl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/e61d221f/attachment-0001.html>
