[Qgis-developer] qgis-dev segfaults on startup
Paolo Cavallini cavallini at faunalia.it
Fri May 20 03:25:49 PDT 2016
Thanks Even,
see below.
All the best.
Il 20/05/2016 12:21, Even Rouault ha scritto:
> Launching with gdb (apt-get install gdb) and getting a stacktrace might help
> understanding where the issue is
> $ gdb qgis
> run
> (and when it crashes) bt
run
[New Thread 0x7fff67ffd700 (LWP 1604)]
Warning: QNetworkDiskCache::prepare() The cache directory is not set
Program received signal SIGSEGV, Segmentation fault.
0x00007fff5e049d0a in ?? () from /usr/lib/libqgispython.so.2.15.0
bt
#0  0x00007fff5e049d0a in ?? () from /usr/lib/libqgispython.so.2.15.0
#1  0x00007fff5e050af6 in ?? () from /usr/lib/libqgispython.so.2.15.0
#2  0x00007fff5e04ebac in ?? () from /usr/lib/libqgispython.so.2.15.0
#3  0x00007fff5e05027d in ?? () from /usr/lib/libqgispython.so.2.15.0
#4  0x00007ffff7627987 in QgisApp::loadPythonSupport() () from
/usr/lib/libqgis_app.so.2.15.0
#5  0x00007ffff7629bb3 in QgisApp::QgisApp(QSplashScreen*, bool, bool,
QWidget*, QFlags<Qt::WindowType>) ()
   from /usr/lib/libqgis_app.so.2.15.0
#6  0x0000555555559e12 in ?? ()
#7  0x00007fffede595f0 in __libc_start_main (main=0x555555558c10,
argc=1, argv=0x7fffffffe2b8, init=<optimized out>,
    fini=<optimized out>, rtld_fini=<optimized out>,
stack_end=0x7fffffffe2a8) at libc-start.c:291
#8  0x000055555555e9b9 in _start ()
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
