[Qgis-developer] Removing overlap creates records with NULL geom
Arnaud Morvan arnaud.morvan at camptocamp.com
Fri May 20 05:48:12 PDT 2016
This should fix the problem : https://github.com/qgis/QGIS/pull/3087
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 20/05/2016 12:12, Paolo Cavallini a écrit :
> Hi all,
> when digitizing with the Avoid intersection function, if a new polygon
> is completely contained in an older one, a record with a NULL geometry
> is created. I'm not sure this is a good idea, maybe better to remove the
> record and/or warn the user?
> All the best, and thanks.
