[Qgis-developer] Autotrace stopped working?
Paolo Cavallini
cavallini at faunalia.it
Fri May 20 22:54:50 PDT 2016
Hi Martin,
thanks for your reply.
Il 20/05/2016 20:22, Martin Dobias ha scritto:
> Both autotrace plugin and tracing functionality since 2.14 should work
> fine... not sure which one you are referring to - and what is the
> snapping configuration you have used.
This is what I did:
* load a polygon layer
* set the snapping options to 10 pixel, vertex only
* start editing
* click on Enable tracing
* click on Add feature
* first click outside current polygons, second close to it (I see the
pink cross indicating snap)
* I move close to the border, but no polygon is traced.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
