[Qgis-developer] Processing, Python 3 and Qt5
Victor Olaya
volayaf at gmail.com
Sun May 22 21:41:56 PDT 2016
Awesome!!
Definitely, having a good test suite will help with that. Maybe that
should be one of our work priorities for the hackfest.
Great work!
2016-05-23 1:07 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi,
> A short update on porting plugins, python 3 and qt5. Today I had success
> with running the processing tests on a py3/qt5 build. For the qgis
> algorithms for which tests exist, there was just one single small
> difference, where the py3/qt5 version offered an increased precision in some
> statistics. Apart from this, everything (what is tested) works fine.
> This is very good news. The py3/qt5 version of the plugin is produced by the
> 2to3 update script and the update script therefore is doing a quite good job
> already if it's able to migrate a complex plugin like processing.
> Apart from this, it is yet another set of tests that prevents us from
> introducing regressions while working on and updating the (python) API in
> the migration process.
> I'm looking forward to seeing more processing tests being introduced to
> guarantee for a smooth transition.
> All the best
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
