[Qgis-developer] datetime difference between 2 datetimes in Field Calculator
Nyall Dawson
nyall.dawson at gmail.com
Mon May 23 02:41:11 PDT 2016
On 23 May 2016 at 19:12, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> I have a start-datetime (string) and a an end-datetime (string) in the
> attributes of my vector data.
> I can use the to_datetime(str) function in the Field Calculator to create
> DateTime objects from these.
> But now it would be cool to check the time-difference between those two
> (called timespan?).
> I did not find a function for those...
Use the age() function. That takes two datetimes and returns an
interval length between them. You can extract the
seconds/minutes/hours/etc from an interval type using the seconds(),
minutes(), ... etc functions.
Hope that helps!
Nyall
> Any hints?
> If I did not miss something, I think there is not even a Qt function for
> this...
> A function to add could be: 'to_timemillies', then the user could create
> timemillies from the DateTime-objects, and do some calculation on those
> him/herself...
> Would that be usefull?
> Regards,
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
