[Qgis-developer] QGIS compiling with Qt5 and Python3 on Debian
Vincent Picavet (ml) vincent.ml at oslandia.com
Thu May 26 10:43:36 PDT 2016
Hello,
On 26/05/2016 19:31, Paolo Cavallini wrote:
> Hi all,
> I was finally able to compile, install, and run (thanks Matthias!) the
> above on a clean virtual machine. I've added the list of necessary
> packages to the INSTALL doc in master. Others please try and report.
> In case someone would need it, I can upload the VM somewhere.
Good news !
Do you have a Vagrant file we could use (and publish) to generate the VM
directly ?
Vincent
