[Qgis-developer] LayerTree group checkbox behavior
DelazJ delazj at gmail.com
Fri May 27 10:59:00 PDT 2016
I do not have a strong opinion on this and as far as we do not visually
offer something that puzzles the user, i'm ok and grayed representation can
be a solution.
Then, considering an unchecked group, how would layers (and group)
visibility behave if:
- I check a not previously checked layer in the group?
- I check a layer that was previously checked (and visible)?
Regards
2016-05-27 19:41 GMT+02:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
> Hi DelazJ,
> Thanks for raising the difference between my proposal and Franck's ticket.
> But this not seems really different.
> The ticket says that when unchecking a group all layers should be
> unchecked.
> IMHO another visual sign should be used (layer grayed, like when the layer
> is not visible due to scale).
> Regards
> Le 27/05/2016 19:32, DelazJ a écrit :
> Hi,
> I often used the group to group layers about same thematics and perform
> layout by simply checking the group (or viewing maps about that thematic).
> This was before preset and multi styles land in QGIS but I suppose I may
> not be the only one doing this.
> Arnaud, I'm not really able to link your comment below to the proposal in
> the issue.
> > When I uncheck a layer group, I expect children to be hidden but not
> unchecked.
> With your proposal, would that mean that you can have a layer checked, but
> because he is under an unchecked group, none of its features is displayed
> in the canvas? Wouldn't that puzzle users?
> If I understand Franck report, with a simple click on group level, layers
> are all unchecked but next click only checks the previously checked, not
> all the layers.
> Do I misunderstand something?
> 2016-05-27 17:08 GMT+02:00 Raymond Nijssen <r.nijssen at terglobo.nl>:
>> Totally agree it should work as requested.
>> Raymond
>> On 27-05-16 17:03, Arnaud Morvan wrote:
>> > Hello,
>> > One of our customer want this ticket to be done :
>> > https://hub.qgis.org/issues/14547
>> > For myself, I agree that the actual behavior of layer tree groups is a
>> > little disappointing.
>> > unchecked.
>> > On the same way, when I check a layer group, I expect checked children
>> > to be shown, but not those who are'nt checked to be checked.
>> > Does anyone have an opinion on this ?
>> > Regard
>> > Arnaud Morvan
>> > Camptocamp
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Terglobo
>> Fahrenheitstraat 1
>> 5223 BJ 's-Hertogenbosch
>> 06 25 31 49 83 <06%2025%2031%2049%2083>
> Qgis-developer mailing listQgis-developer at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160527/58687b2e/attachment.html>
