[Qgis-developer] [Processing] Parameters and widgets refactoring
Victor Olaya
volayaf at gmail.com
Sat May 28 00:00:29 PDT 2016
I like this design a lot. That will give us a cleaner structure and a
code that is easier to understand.
Definitely this has to be in 3.0, although it will be quite a bit of work.
Any additional comment from anyone?
Arnaud, will you at camptocamp be able to dedicate time to this task?
Let's see how we can better organize it
Thanks!
2016-05-27 18:59 GMT+02:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
> Here the idea to create some class to get processing UI more modular,
> flexible and more user friendly.
> Actually in processing all parameter's widgets are hardcoded in
> ParametersPanel, depending on parameter types. This is not flexible to
> create custom parameters and related panels.
> On top of this, we have a lot of code duplicated between :
> Standard algorithm dialog/panel
> Batch dialog/panel
> Modeler dialog/panel
> A more modular vision could be to create a widget class for each parameter
> type.
> ParametersPanel would only have to iterate over parameters and create
> appropriate widgets.
> Using this, it could be easy to create new parameter types and related
> widgets without creating a custom dialog and panel class for each case.
> Proposed design:
> Parameter class would have a new "widget" attribute (name as string) and
> optionally widget options.
> Existing parameters will have a default widget name already given.
> Processing UI will maintain a global a registry for widgets (name =>
> class)
> Each processing plugin could register it's own parameters types and
> related widgets.
> Each algorithm could override the default widget for a given parameter.
> With this design, we have a dissociation between the parameters that are
> core related and widgets that are ui oriented. Widgets could be easily
> extended without altering the core.
> For example, in postgis related algorithms, it could be possible to create
> custom widgets, capable of database introspection using existing GeoDB class
> to propose drop down lists of schemas and tables or primary keys and
> geometry column detection, without altering existing parameter types.
> This is a draft, your comments are welcome.
> Arnaud Morvan
> Camptocamp
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
