[Qgis-developer] [Processing] General programming issues
Niccolò Marchi sciurusurbanus at hotmail.it
Sat May 28 10:32:40 PDT 2016
Hi all,
sorry for the noob questions, but I’m struggling to find a solution to some simple issues.
I’m working on the Processing interface with a 3rd party software (i.e. FUSION). I’m not a programmer , so be patient!
1.       TEMPFILELIST: when I select more input files, a static method is called to write a temp list (to be used as wildcard). Actually the code says “filepath = userFolder() + os.sep + filename” and it doesn’t work, but if I set up a specific folder instead of userFolder, it works fine. Does it lose the way of the temp path?
2.       ACCESS TO SHAPEFILE: if I use a shapefile already opened in qgis for a clipping operation, the software (FUSION) has problems to access to it (and stops working); if I do the same operation with a shapefile not loaded in qgis, it works fine. Does qgis block files while reading them (as arcgis does with “.lock” temp files)?
3.       MODELER: Building up a model with FUSION tools, I’m obliged to fill also optional parameters to make the algorithm work, otherwise I receive the error “Wrong or missing value”. How can I solve this?
4.       OPTIONAL PARAMETERS: In the graphical panel of each algorithm, some parameters (i.e. input) automatically appear as “…[optional]” while they clearly aren’t. Where is it possible to change this behaviour?
I specify I’m using QGIS (2.14.3) on W10 64 bit.
Thank you VERY much in advance for those who have time&willing to answer  😊
Keep up with the good work!
All the best,
Nic
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160528/3c7ba19c/attachment.html>
