[Qgis-developer] [SoC] Report 1 - QGIS Symbology Sharing Tools
Akbar Gumbira
akbargumbira at gmail.com
Tue May 31 01:16:46 PDT 2016
HI Massimo,
Thanks. Now I can build it. Anyway, we decided to make it as python plugin
first and make it similar like Plugin Manager later.
Cheers
On Mon, May 30, 2016 at 5:40 PM, Massimo Di Stefano <epiesasha at me.com>
wrote:
> Akbar,
> Marco and I added a commented on your gist.
> Did you fixed the build?
> On May 29, 2016, at 10:48 AM, Akbar Gumbira <akbargumbira at gmail.com>
> wrote:
> Hi All,
> Here is my report for the first week of GSoC
> *What did you get done this week?*
> During community bonding period and 1st week, I spent my time discussing
> with the community about the idea. We had a long email and comment
> discussion even before we met in QGIS Hackfest. Right now the way I will go
> is to use directory based for the repository. So this week I spent my time
> mostly on shaping the idea with my mentors (Anita, Ale), Tim, Richard,
> Martin, and other developers in QGIS Hackfest.
> *What do you plan on doing next week?*
> Next week, I will start implementing the UI.
> *Are you blocked on anything?*
> Yes, I couldn't build QGIS on master branch on Ubuntu 16.04 (it's fine
> with other release branch), I've tried to remove the build folder (even
> completely cloning it again - I am desperate enough). I'll look more into
> it. You can see the error log here:
> https://gist.github.com/akbargumbira/4221338b4b3042dcc144cd78aeb6ca69
> I also made a blog post here
> http://www.akbargumbira.com/gsoc-1-defining-use-cases-and-hackfest/
> Cheers
> *Akbar Gumbira *
> *www.akbargumbira.com <http://www.akbargumbira.com/>*
> SoC mailing list
> SoC at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/soc
*Akbar Gumbira *
*www.akbargumbira.com <http://www.akbargumbira.com>*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160531/cdde9350/attachment.html>
