[Qgis-developer] issue in exported SLD for categories symbology
Andrea Aime andrea.aime at geo-solutions.it
Wed Nov 2 06:12:29 PDT 2016
Hi Victor,
that would be a good usage of <ElseFilter/>, which is indeed designed
to match all features not matched by other rules in the same
featuretypestyle
Cheers
Andrea
On Wed, Nov 2, 2016 at 2:09 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Hi
> It seems that there is an issue with SLD exports. When exporting
> categorical symbology in which a default value is defined (for all
> values not matching any of the categories) a rule-based symbology is
> created. However, the default category has no ELSE in it (as it
> should), and the default symbol is applied to all elements, since it
> has no filter, and shadows the rest of the symbology.
> Morever, when a rule-based symbology is defined as rule-based, and the
> ELSE condition is added, it is not exported. The resulting SLD has
> something like this:
> <se:Rule>
>          <se:Name></se:Name>
>          <!--Parser Error: syntax error, unexpected ELSE - Expression
> was: ELSE-->
>          <se:PolygonSymbolizer>
>            <se:Fill>
>              <se:SvgParameter name="fill">#9a5ceb </se:SvgParameter>
>            </se:Fill>
>            <se:Stroke>
>              <se:SvgParameter name="stroke">#000001 </se:SvgParameter>
>              <se:SvgParameter name="stroke-width">1</se:SvgParameter>
>              <se:SvgParameter name="stroke-linejoin">bevel</
> se:SvgParameter>
>            </se:Stroke>
>          </se:PolygonSymbolizer>
>        </se:Rule>
> Is that a known limitation, or is it like that for some reason?
> For the record, the resulting SLD is correctly rendered in GeoServer,
> so maybe there is some issue in how QGIS handles those default
> categories. Opening the exported SLD and using it for a layer in QGIS
> causes all feature to be rendered with the default symbol.
> It might be related to this issue:
> http://hub.qgis.org/issues/15430
> Thanks!
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161102/f8ef36fb/attachment-0001.html>
