[Qgis-developer] [Qgis-user] Geojson URL's
Pasquale Di Donato
pasquale.didonato at gmail.com
Mon Nov 14 01:07:33 PST 2016
Just FYI, a couple of months ago I had the same issue with password secured
GeoJSON files over https and under proxy.
The access to the GeoJSON files worked without any problem without the
proxy.
Under the proxy I had to set the environment variable as said in a previous
email.
On Mon, Nov 14, 2016 at 8:43 AM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Il 13/11/2016 10:23, Richard Duivenvoorde ha scritto:
> > BUT IF this works, it woul be nice to maybe make this part of a normal
> > QGIS setup:
> > IF a user set's a proxy, also create a environment variable for GDAL!
> > Another option would maybe to have some wrapper around GDAL, or make
> > GDAL aware of using QTNetworkManager via that wrapper?
> > Does this makes sense?
> Sure, all network settings should be centralized.
> IMHO better opening a ticket, not to forget about this, and of course
> helping to find a solution.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161114/d6525e24/attachment.html>
