[Qgis-developer] delete selected features slow (because of featurecount/events)??
Matthias Kuhn
matthias at opengis.ch
Wed Nov 16 01:46:20 PST 2016
Hi Richard,
What the trash button does is
vl.beginEditCommand( "Delete Selected Features" )
vl.deleteSelectedFeatures()
vl.endEditCommand()
This makes me think, that the "with edit" construct could actually wrap
things into a single edit command as well.
Matthias
On 11/14/2016 04:55 PM, Richard Duivenvoorde wrote:
> Hi Dev's,
> having a small dataset of 300 features (from an online service).
> I want to quickly remove most/all of those features, request a new set
> an put them in the same vectorlayer (in a python plugin).
> All ok, untill you activate the 'show feature count' in the legend.
> If you show the featurecount, it looks like the features are deleted one
> by one: you can see the featurecount go down to zero... ( but I also
> have dataset with a lot more features :-( ) and it takes several (ten's)
> seconds.
> Easy testable:
> - load some data, tick the 'show feature count' tickbox in the legend.
> - make the layer editable and select all features
> - make sure the layer is current in the legend
> do the following in the python console:
> l=iface.mapCanvas().currentLayer()
> you can see the 'feature count' go down one by one (slowly...)
> while... if you do it outside of python, using the little red
> delete-basket in the edit-toolbar. All features are deleted in a blink!
> Also if you show the featurecount...
> I tried some different ways, but could not find a quick way?
> Do I miss something/a quicker way?
> I thought that it maybe had something to do with filling up the
> 'editbuffer', so tried with and without the 'edit' construct [0]
> But in this case I just do not want an edit-buffer anyway..
> Regards,
> [0]
> http://www.opengis.ch/2015/08/12/with-edit-layer/#avoid-using-dataprovider-methods
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
