[Qgis-developer] Changing ergonomy of the visibility of layers inside groups ?
Even Rouault
even.rouault at spatialys.com
Wed Nov 16 05:44:52 PST 2016
> Another scenario would be:
> When clicking, the group toggle between unchecked, partially checked,
> checked. At the same time it caches the state for all subitems to
> restore the partially checked state when switching to this.
> At any time, when a subitems check state is changed, all parents
> invalidate their cached states and override it with the new partial
> check state. If the last remaining unchecked item is checked (and vice
> versa) clicking the group skips the partially checked state...
> Maybe that would be more natural?
So imagine you have an initial state with a group G checked and its layers A
and B checked
You click on G ==> it becomes unchecked, and A and B as well
You click on G ==> it becomes checked, and A and B as well
You click on A to unselect it ==> G becomes partially checked. And you save
current state of A and B as StatePartial
You click on G ==> it becomes partially checked, and you restore StatePartial
(ie A is unchecked and B is checked)
You check on A ==> it becomes checked and G as well (and clicking on G would
switch between all on - all off)
You uncheck A --> G becomes partially checked
You uncheck B --> G becomes unchecked (and clicking on G would switch between
all on - all off)
Is that what you meant ? That makes sense to me.
Besides a slightly more complicated implementation, one downside would be that
cycling between (partially)on state and off state of a group (with different
check state of its items) would require 1.5 clicks on average (1 click to go
from unchecked to partially checked, 2 from partially checked to unchecked)
instead of 1. I should check with the users if they can afford the extra half
click :-)
Thanks for your suggestions.
http://www.spatialys.com
