[Qgis-developer] PyQgsOfflineEditingWFS disabled on Travis
Alessandro Pasotti
apasotti at gmail.com
Wed Nov 16 07:51:00 PST 2016
On Wed, Nov 16, 2016 at 4:22 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> On 11/16/2016 03:48 PM, Alessandro Pasotti wrote:
> > On Wed, Nov 16, 2016 at 3:07 PM, Matthias Kuhn <matthias at opengis.ch
> > It might be a problem in the test, but a segmentation fault could be a
> > signal of something more serious in the core on in the bindings.
> > From the build history, this particular test does not seem to be
> > randomly failing but consistently failing since b32a719
> > <https://github.com/qgis/QGIS/commit/b32a719798917611c0a30bd044e55a
> c7ce4e423b>
> > , even if you reverted that single commit with no changes in the
> > failure, that does not imply that the test was broken.
> I fully agree with you. What would you propose to do?
> Matthias
What you are doing right now (https://github.com/qgis/QGIS/pull/3774) seems
quite promising :) Thanks!
BTW were you able to reproduce the segfault on your local machine?
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161116/b4960876/attachment.html>
