[Qgis-developer] DB Manager and other PostGIS issues: notes from a course
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Nov 21 03:01:14 PST 2016
Hi all,
> * DB Manager
> * create table: field types are limited; in particular, timestamptz is
> missing
old issue, old as db manager, it only shows a subset of available datatypes.
> * create table: SRID has to be entered by hand; the projection widget
> should be added
see above: it has always been so in DB manager.
> * edit table -> Table properties -> Field properties: the field
> `Length` appears wrong; for geom it shows `geomtype,srid`, for
> varchar(255) and others, adding a length will cause an error:
> ALTER TABLE "public"."buffer_union" ALTER "round" TYPE varchar(255) (24)
> length has to be entered by hand changing varchar(255) into e.g. varchar(20)
see above: old as db manager. If you choose a datatype with a
predefined length then manually changing the length causes an invalid
query to be run.
> * we got frequent errors similar to [0]
confirmed. This does not seems to be the case in LTR, so this
configures as a regression.
> * Browser
> * importing a shapefile of points results in a (generally undesirable)
> MULTIPOINT, without a possibility of choice for the user
> * a table created with SRID=0
> CREATE TABLE pt
> (id INTEGER, name text, geom GEOMETRY(Point,0,2));
> INSERT INTO pt (id, name, geom)
> VALUES (1, 'Origin', ST_GeomFromText('POINT(0 0)', 0));
> results in two entries: one with mouseover= geom as Point in 0 and one
> geom as Point in -2147483648
confirmed down to 2.8.* so not sure is a regression.
> * Processing
> * there are two Import into Processing (one QGIS and one OGR)
the OGR based tool is necessary because is the only one available that
is fast enough. It is 8+ times faster than any other tool available in
QGIS making it the only tool good enough to import into postgis large
layers.
> * for the first (QGIS), batch processing fails with `Missing parameter
> value: Table to import to (leave blank to use layer name (row 1)`
the "table name" parameter has been incorrectly set as mandatory. This
is not the case in LTR, so this is a regression.
> * for the second (OGR), it also fails because it tries to write in the
> spatial_ref_sys (CRS should default to source CRS) [1]
I will make the input/output CRS parameters mandatory.
> * the gdal output is not interpreted correctly (html and encoding) [1]
cannot confirm.
cheers
-- G --
