[Qgis-developer] Missing QgsApplication.instance().argv in master
Alessandro Pasotti
apasotti at gmail.com
Mon Nov 28 06:55:10 PST 2016
On Mon, Nov 28, 2016 at 3:44 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Alessandro,
> QApplication is part of PyQt, did you check if it also changed if you
> run a non-QGIS pyqt application?
Yes, it seems so:
>>> from PyQt5.QtWidgets import QApplication, QWidget
>>> a = QApplication([])
>>> a.argv()
File "<stdin>", line 1, in <module>
AttributeError: 'QApplication' object has no attribute 'argv'
In [2]: import sys
...: from PyQt4 import Qt
...: a = Qt.QApplication(sys.argv)
In [3]: a.argv()
Out[3]: ['/usr/local/bin/ipython']
Now I wonder if this is a PyQt bug or something changed in Qt itself
Is there anything we can do to get the argv/argc in a python script running
inside QGIS?
This is needed by the testing environment in
https://github.com/boundlessgeo/qgis-testing-environment-docker/blob/master/qgis_testrunner.py#L150
fortunately, there are some workarounds.
> Matthias
> On 11/28/2016 03:35 PM, Alessandro Pasotti wrote:
> > Hi,
> > the following code is working fine in 2.x but not in master:
> >>>> QgsApplication.instance().argv()
> > File "/usr/lib/python3.5/code.py", line 91, in runcode
> > exec(code, self.locals)
> > File "<input>", line 1, in <module>
> > I looked at the sip file but I did not find the reason why it's now
> > failing, any idea what has changed in this regard?
> > Alessandro Pasotti
> > w3: www.itopen.it <http://www.itopen.it>
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161128/f8df0e82/attachment.html>
