[Qgis-developer] DB manager: Connection to PostGIS from QGIS3 fails
Arnaud Morvan arnaud.morvan at camptocamp.com
Wed Nov 30 01:28:52 PST 2016
Hello Paolo
I've the same problem, but not found the time to search and fix it.
Regards
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 29/11/2016 12:51, Paolo Cavallini a écrit :
> Hi all,
> testing QGIS master, I am noticing that the connection to PostGIS
> through the browser is OK, whereas the same through DBM attempts to find
> a 'g' schema, which is not there, and fails:
> SELECT has_schema_privilege('g', 'CREATE'), has_schema_privilege('g',
> 'USAGE')
> Is this a local problem?
> All the best.
