[Qgis-developer] Multiple Fields in R-Processing
Victor Olaya
volayaf at gmail.com
Sat Oct 1 05:31:49 PDT 2016
mmm, it is working for me
this works fine
##layer=vector
##fields=multiple field layer
print fields
Notice that it is "multiple field", all in lower case. You example
says "multiple Field", which is wrong. Maybe is that?
2016-09-30 10:19 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi Victor,
> thanks for your answer..
>> The value of the multiple flieds is a string with field names
>> separated by semicolons
>> so, to get a list of them:
>> fields = multiple_fields.split(";")
>> Not sure this is what you need...maybe I am not understanding the question....
> actually not :)
> a small example is.. I have a vector layer with some fields and I want
> to perform normality test on some of the fields..
> so I have 2 options:
> 1. create many ##field1 = Field Layer and give to some of them the label
> optional because the user doesn't know how many fields would be in input..
> 2. use ##fields = multiple Field Layer that, as you said, throws out a
> list with all the field names separated by ";" and loop on that columns
> now the problem with my R script is that I cannot get the variable with
> the selected fields, for example:
> ##Vector processing=group
> ##Layer=vector
> aa = fields
>>aa
> even to do in this way (so just printing the entire string of all the
> field names) throws the error:
> Error: unexpected symbol in " multiple Field"
> I try your suggestion (f = fields.split(";")) but I get the same error
> of above again.
> For sure I'm missing something, but I really don't understand what..
> Thanks again Victor!
> Cheers
> Matteo
