[Qgis-developer] Multiple Fields in R-Processing
Victor Olaya
volayaf at gmail.com
Sat Oct 1 09:43:19 PDT 2016
ah, ok, that might be it
can you check the temporary R file that is created when running the
algorithm? that should tell you how the parameter is pased to R, since
that is an R script
You should find it in ~/.qgis2/processing
regards
2016-10-01 18:21 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi Victor,
> again, thanks for the support.
> I still have troubles.. always the same error (actually lower or
> uppercase is the same)..
> I'm talking of R scripts, not python ones.. are there differences?
> Thanks again
> Matteo
