[Qgis-developer] Fwd: Re: [Geopackage] Geopackage on a shared network drive
Even Rouault
even.rouault at spatialys.com
Mon Oct 3 02:49:52 PDT 2016
Le lundi 03 octobre 2016 10:33:25, Neumann, Andreas a écrit :
> Hi Even,
> Thank you for sharing this finding!
> In that case I think that QGIS should offer a flag to open Geopackages
> in read-only mode.
<probably_ignore_this_and_skip_to_last_paragraph>
I'm not sure we need an explicit flag for read-only mode (in the GUI I mean).
This could bring some complications: for example should that be saved with the
layer in a project file? But if so, then you'd be stuck to read-only later if
you want to edit a layer, etc.
Read-only mode could be the default mode for opening, and re-open in read-
write mode when this is needed. This is something I've done recently, but
limited to MapInfo .tab, since opening .tab files in read-write mode prevented
concurrent opening of the file in QGIS & MapInfo. I didn't want to mess with
other formats, but fundamentally I don't see any reason why this couldn't be
generalized to other formats (I'm not sure why QGIS has historically opened in
read-write mode as first try. Probably because this was easier to implement)
For GPKG, there's just one subtelty though. I've fixed recently #15351 and to
avoid deadlocks between readers&writers, the first to open a GPKG needs to turn
on write ahead log (WAL) journalisation, so the workflow would be :
- open in read only
- check if journalisation is WAL
- if so, done
- if not, re-open in read-write, turn on WAL, re-open in read-only
And similar on closing to revert to the default DELETE journalisation mode.
</probably_ignore_this_and_skip_to_last_paragraph>
Hum, with further thinking, I don't undertstand why my suggestion in the
discussion thread on the geopackage ML of changing the file permission to read-
only made things faster. Because, for feature iterators, QGIS uses a dedicated
OGR connection in read-only mode and does not use the provider connection that
might be in read-write mode. Unless the reporter still uses GDAL 1.11, which
used to open in read-write mode regardless of what the user specified (was fixed
in GDAL 2.0). That must be it. I'll check back with the reporter. So probably
all the above is not needed after all...
> Even - since you are "Mr. Geopackage" in the QGIS project anyway - can
> you please make sure that this can be covered in the upcoming Geopackage
> improvements? Would a "read-only" mode also be useful for other data
> formats? I opened a ticket at http://hub.qgis.org/issues/15652 and
> assigned it to you. I have no idea how much effort this enhancement
> would mean - can you please do an estimate and send me a quote for that?
> Maybe we could still include it in the upcoming Geopackage improvements
> financed by the Swiss QGIS user group.
> This also leads to a follow up question: many OGR data formats have
> "open options". As far as I know, these options are not exposed to the
> User in QGIS, other than the encoding - or did I miss something? Should
> we introduce a "GUI" way in QGIS 3.x to expose these "open options" in
> the "add vector layer" dialogue?
Open options cannot be specified through QGIS currently indeed. There are not
so many vector drivers that expose them, mostly those who are of the database
type (with some redundancy with the way configuring the connection is already
offered in the GUI). Some notable exceptions in the regular file category are
CSV and GML.
One downside of open options is that they can be rather esoteric and hard to
understand for the average user, so I guess they should be presented in a
expandable tab.
GDAL offers the possibility to auto-discover which open options are available
for a format, but that doesn't solve the issue with internationalization in
QGIS. Although I think I discussed with someone about this and one possibility
mentionned was to dump, at QGIS build time, the strings to translate from GDAL
in a QGIS resource file. I didn't look how internationalization worked in QGIS.
Even
http://www.spatialys.com
