[Qgis-developer] Questions around xyz tile server connections in master 2
Neumann, Andreas
a.neumann at carto.net
Tue Oct 4 08:58:20 PDT 2016
Hi Saber,
I totally agree. It is great to have it in core. We just need to bring
it "on par" with the usability of e.g. the QuickMapServices. Otherwise,
people will just continue to use this plugin instead of the core QGIS
functionality.
BTW: the QuickMapServices plugin also supports transparency, brightness,
contrast, grayscale, blend modes, smoothing, etc.
Thanks and greetings,
Andreas
On 2016-10-04 16:31, Saber Razmjooei wrote:
> Hi Andreas,
> From user point of view, there is one other (very obvious) benefit of having the native support: styling the XYZ layer. You can now adjust the transparency, set blend mode/color rendering, etc similar to other rasters in QGIS.
> Regards
> Saber
> FROM: Neumann, Andreas [mailto:a.neumann at carto.net]
> SENT: 04 October 2016 10:08
> TO: Saber Razmjooei
> CC: 'QGIS Developers List'
> SUBJECT: RE: [Qgis-developer] Questions around xyz tile server connections in master 2
> oh - SRP was indeed turned off. Silly me!
> Still I find that the "standard" methods of adding layers in QGIS should also be provided for the tile servers, such as "Layer management toolbar" and Menu "Layer --> AddLayer --> Add tile map server layer". I personally normally don't use the QGIS browser panel and this means that I can't add tile maps if this panel is not open. Or maybe the xyz tile map servers could be integrated with the WMS/WMTS layer loading dialogue?
> Thanks for your reply!
> Andreas
> On 2016-10-04 10:52, Saber Razmjooei wrote:
> Hi Andreas,
> It works fine with my layers and the OTF on.
> Including some default services would be great, but unfortunately there are some restrictions in using the service.
> See the original discussions here:
> https://github.com/qgis/QGIS/pull/3473
> Cheers
> Saber
> FROM: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] ON BEHALF OF Neumann, Andreas
> SENT: 04 October 2016 09:33
> TO: QGIS Developers List
> SUBJECT: Re: [Qgis-developer] Questions around xyz tile server connections in master 2
> So I found out that http://tile.openstreetmap.org/{z}/{x}/{y}.png [1] seems to work.
> However, if I add this OSM layer to my Swiss QGIS project (EPSG:21781) - the swiss data seems to appear in the atlantic, west of "Guinea Ecuatorial" ;-(
> Andreas
> On 2016-10-04 09:48, Neumann, Andreas wrote:
> Hi,
> I have a couple of questions around the new "Tileserver" layer support in QGIS desktop to be released with 2.18. I think the main commit is https://github.com/qgis/QGIS/commit/f5b657db19eda7e72e6ed34eb7fe333c156acad0 - right?
> First, let me thank you a lot for this - Martin and Lutra Consulting for developing/sponsoring it!
> However, I wonder if the usability of the newly added tilserver is already good enough? Or at least I think it is not really obvious how to use it.
> 1. How can add a new connection to a tile server? Is the browser the only way? If yes, I hope that an additional entry to Layer --> Add Layer menu could be added - all other layer types can be added this way.
> 2. What is a correct URL? This is really hard to find out. F.e. I went to http://wiki.openstreetmap.org/wiki/Tile_servers and tried to copy some URLs and failed about finding the correct syntax. I added the layer to the project --> nothing happened. No display, no error message. Maybe because the projections do not match? - or would QGIS reproject on the fly?
> 3. Can we add some popular tile map server URLs by default - similar to the QuickMapServices plugin?
> 4. How can one edit an existing tile server connection - e.b. change title or URL? Currently, one can only delete and re-add it.
> Thank you for your reply,
> Andreas
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viru ses is taken and it is your responsibility to carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions [2] shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Links:
[1] http://tile.openstreetmap.org/%7bz%7d/%7bx%7d/%7by%7d.png
[2]
http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161004/5a72a2b4/attachment-0001.html>
