[Qgis-developer] Issue with Python on Fedora
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Wed Oct  5 00:49:28 PDT 2016
Hi all,
Thanks a lot to Tudor, Sandro and Richard for your input.
To solve the issue, I had to do
export LD_LIBRARY_PATH=/usr/lib:$LD_LIBRARY_PATH
This seems a bit strange to me, shouldn't /usr/lib be automaticaly used?
Does this means that installation somehow fails to place the lib in the
proper place? /usr/lib64?
Cheers,
Denis
On 10/04/2016 02:18 PM, Richard Duivenvoorde wrote:
> On 04-10-16 10:15, Denis Rouzaud wrote:
>> Hi all,
>> I have an issue with Python on Fedora.
>> After installing from a new clean clone and fresh build dir, if I do
>>  PYTHONPATH=$PYTHONPATH:/usr/share/qgis/python python -m qgis.PyQt.uic.pyuic
>> I get
>> /usr/bin/python: libqgis_core.so.2.17.0: cannot open shared object file:
>> No such file or directory
>> Although the lib is indeed in /usr/lib.
>> Also, if I run qgis from the build output and do
>> From qgis.PyQt.uic import pyuic it crashes without any backtrace.
>> I don't know what to look for.
>> There are some issues on the hub, but I cannot find the connection with
>> this one.
> Hi Denis,
> should you not also set LD_LIBRARY_PATH? It looks like something is not
> picking up your fresh lib files?
> I compile/install myself in a custom dir, and have to set this both for
> running QGIS or to run pyqgis stuff
> export LD_LIBRARY_PATH=/home/richard/apps/qgis/master/debug/lib/
> I also have another 'set environment' script, that set's the
> export QGIS_PREFIX_PATH=/home/richard/apps/qgis/master/debug
> maybe try that? Not sure what really is picked up to be honest.
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161005/20738c43/attachment.html>
