[Qgis-developer] Issue with Python on Fedora
Sandro Mani
manisandro at gmail.com
Wed Oct 5 00:59:11 PDT 2016
Hi Denis
You can adjust the lib install dir when configuring cmake by specifying
|-DQGIS_LIB_SUBDIR=lib64 And yes, on Fedora /usr/lib is for 32bit libs,
/usr/lib64 for 64bit libs. Sandro |
On 05.10.2016 09:49, Denis Rouzaud wrote:
> Hi all,
> Thanks a lot to Tudor, Sandro and Richard for your input.
> To solve the issue, I had to do
> export LD_LIBRARY_PATH=/usr/lib:$LD_LIBRARY_PATH
> This seems a bit strange to me, shouldn't /usr/lib be automaticaly used?
> Does this means that installation somehow fails to place the lib in
> the proper place? /usr/lib64?
> Cheers,
> Denis
> On 10/04/2016 02:18 PM, Richard Duivenvoorde wrote:
>> On 04-10-16 10:15, Denis Rouzaud wrote:
>>> Hi all,
>>> I have an issue with Python on Fedora.
>>> After installing from a new clean clone and fresh build dir, if I do
>>> PYTHONPATH=$PYTHONPATH:/usr/share/qgis/python python -m qgis.PyQt.uic.pyuic
>>> I get
>>> /usr/bin/python: libqgis_core.so.2.17.0: cannot open shared object file:
>>> No such file or directory
>>> Although the lib is indeed in /usr/lib.
>>> Also, if I run qgis from the build output and do
>>> From qgis.PyQt.uic import pyuic it crashes without any backtrace.
>>> I don't know what to look for.
>>> There are some issues on the hub, but I cannot find the connection with
>>> this one.
>> Hi Denis,
>> should you not also set LD_LIBRARY_PATH? It looks like something is not
>> picking up your fresh lib files?
>> I compile/install myself in a custom dir, and have to set this both for
>> running QGIS or to run pyqgis stuff
>> export LD_LIBRARY_PATH=/home/richard/apps/qgis/master/debug/lib/
>> I also have another 'set environment' script, that set's the
>> export QGIS_PREFIX_PATH=/home/richard/apps/qgis/master/debug
>> maybe try that? Not sure what really is picked up to be honest.
>> Regards,
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161005/6fd3a7bf/attachment.html>
