[Qgis-developer] gdalwarp fails, Save as... reprojected works
Paolo Cavallini
cavallini at faunalia.it
Sun Oct 9 22:18:46 PDT 2016
Il 09/10/2016 23:31, Even Rouault ha scritto:
> Le dimanche 09 octobre 2016 23:27:04, Victor Olaya a écrit :
>> If the parameter is not needed, it should be optional.
>> If anyone can confirm that, I will make it optional.
> From the doc http://gdal.org/gdalwarp.html, the only required parameters are
> the input and output files :-)
Thanks. IMHO the interface for this module should be less intimidating,
moving optional params to an Advanced section.
As noted, it is possible that other similar modules share the same issue.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
