[Qgis-developer] memory-based layers and projects
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Mon Oct 10 12:33:09 PDT 2016
Hei Martin,
Do you think of something like a python macro to be run at project start?
Then maybe this helps:
http://gis.stackexchange.com/questions/89903/is-there-a-way-to-run-a-python-script-on-opening-a-qgis-project
Cheers
Stefan
-----Original Message-----
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Martin Landa
Sent: 10. oktober 2016 19:20
To: Chris Crook <ccrook at linz.govt.nz>
Cc: qgis-dev <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-developer] memory-based layers and projects
2016-10-10 19:04 GMT+02:00 Chris Crook <ccrook at linz.govt.nz>:
> One option you could use is to install the MemoryLayerSaver plugin.  That saves the data for all memory layers in a project into a file named after the project file.
thanks. But this option is something what I would like to avoid (no new files created, regardless format - SQLite Db or mldata). Ideally to provide to QGIS information how to load data (python code for running plugin reader) and from which file.
Anyway thanks for the feedback! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
