[Qgis-developer] QGIS server improvements
Tudor barascu
tudorbarascu at yahoo.com
Wed Oct 12 00:46:02 PDT 2016
Hi Andreas,
What you just wrote makes perfect sense.I was under the impression that gathering requirements also takes enough time that it may be hard to do it on personal time. So, I think that we should sponsor that so we can get going.
All the best!
On Wed, Oct 12, 2016 at 10:26 AM +0300, "Neumann, Andreas" <a.neumann at carto.net> wrote:
Hi Paolo / Tudor,
I agree that the QGIS server improvements should be started. But you need a clear plan on what to do in what order. Requirements need to go first, otherwise there is no point in selecting devs, getting quotes/estimates and doing a crowd-funding. And probably, several devs will be involved.
I wonder if a QGIS server dev could provide some insight in what needs to be done, exactly. Who has a good overview regarding open issues around QGIS server? Probably Marco?
As to my knowledge, the following items need to be done:
1. The API changes/improvements need to be done first. There are two work items pending:
- Proposal 14 from the QGIS grants titled "Project / Map layer registry refactoring" from Martin Dobias. Most likely, the german and swiss QGIS user group will fund this jointly.
- The GUI/core separation of the widgets, cleanly separate GUI and core for form widgets. This would allow better access to display values in QGIS expressions and better access for (Python) Developers and the QGIS server code base. I have a quote from Matthias Kuhn for approx. 4k €. If someone can fund this, please let me know.
I am sure there are more desired API changes that are useful for QGIS server
2. Then there is the switch from old map renderer to the new one. See https://github.com/qgis/QGIS/pull/3129
I don't know what other work items need to be done to get QGIS server in good shape for QGIS 3.x?
Lets spend some time first, to collect all the requirements before we do any further actions. I think in this situation a QEP, describing what to do in what order, makes a lot of sense. After that we can look into who could do what.
Andreas
On 2016-10-12 09:00, Tudor Barascu wrote:
Hi Paolo,
A big thumbs up!
All the best,
Tudor
On Wednesday, October 12, 2016 8:28 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
Hi all,
after a first bloom of interest around the improvement/rewrite of qgis
server, things seem stagnant nowadays. I suggest therefore to:
* select one or more suitable developers
* obtain an estimate
* start a crowdfunding.
Given the number of interested firms and individuals, I think it should
be easy to reach the goal.
Any objection to start soon?
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161012/dc71db2e/attachment.html>
