[Qgis-developer] Visualisation of relations
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Wed Oct 12 00:48:04 PDT 2016
No answer. I think I'll move forward with my proposal.
Thanks.
On Fri, Oct 7, 2016 at 9:27 AM, Patrick Valsecchi <
patrick.valsecchi at camptocamp.com> wrote:
> Hi,
> I'm tasked with making QGIS a bit more usable with complex database
> schemas having a lot of relations (up to hundreds of linked tables). The
> INSPIRE people were a bit too inspired when creating their data schemas and
> now we have to try to make QGIS able to cope with that.
> My concerns with the current situation (as of QGIS master) are:
> - We can specify the relations between the layers at the project level
> (it's now easier with the auto-discover feature for PostGIS and
> Spatialite). But those are only showing in the QgsAttributeForm for the 1-N
> side (the side that doesn't have the foreign key). Why not on the N-1 side?
> - For showing the N-1 side in the QgsAttributeForm, one can define a
> Join in the layer's properties, but I don't see the point of having to
> define it here as well when we have already the relations info at the
> project level. I see a use for special joins, but for relations, I don't
> see why we have to define it twice. And the way it's displayed is not
> allowing to create joins or edit the joined fields.
> - I let you imagine the look of the feature attribute form when there
> are hundreds of directly and indirectly linked tabled. This is just not
> usable if we display all of them directly like that. Just look at the
> attached screen shot that shows what happens by default with only 3 tables.
> It's already a mess.
> Now, what I propose is:
> - Not expand the relation widget (QgsCollapsibleGroupBox) by default
> and build it's content only when it is expanded the first time (think of
> what would happen when you have loops in the schema).
> - Show N-1 relations as well, in a collapsed by default
> QgsCollapsibleGroupBox, including a way to add a new linked entry, remove
> the link (put the FK to NULL) and delete it.
> - Add a button to open a related feature in a new window.
> What do you guys think?
> Thanks.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161012/026ad389/attachment.html>
