[Qgis-developer] QGIS Server, my last improvements
René-Luc Dhont
rldhont at gmail.com
Wed Oct 12 08:02:10 PDT 2016
Hi Devs,
I'm writting this email to inform you about my last QGIS Server
improvements.
Firstly, when we fixed something in QgsMapLayerRegistry: [BUGFIX] Emit
layerWillBeRemoved like layersWillBeRemoved (#3194)
https://github.com/qgis/QGIS/commit/f6aad8bad6db72d0b1e573998ac7dcb2405dce55;
we generated an issue in QGIS Server: Qgis Server doesnt' respect the
styling from Desktop http://hub.qgis.org/issues/15522.
I investigated the issue 15522 and found that layersWillBeRemoved
results in clearing vector layer join buffers. So layers in QGIS Server
cache has empty join buffer. To fixed it, the only accessible method is
QgsVectorLayer::readXML. But this method does not only reload joins, it
also forces reload data and all other configuration stored in the qgis
project. The uses of these method results it a memory leak. So the good
solution is to add an accessor to the QgsVectorLayer::joinBuffer.
https://github.com/qgis/QGIS/pull/3593
Following the advice of Nyall, I replace dynamic_cast by qobject_cast
when it is usefull. I gained some performances with it.
I opened an other pull request about GetLegendGraphic and layer title,
requested by a customer https://github.com/qgis/QGIS/pull/3595 And it
needs some review
In this PR, I enhance the QGIS Server tests but a lot has to be done.
Regards,
