[Qgis-developer] ogrLayerName in processing/tools/vector.py
Mark Johnson mj10777 at googlemail.com
Tue Oct 18 05:44:59 PDT 2016
> Didn't you use "ctest" ?
Yes, the first list of errors was from that
> PYTHONPATH to include ${BUILDDIR}/output/python/plugins.
Have done that and now am building the latest branch
> using latest tree
> in release-2_16 branch
Before you wrote branch 'master_2'
- that is what I checked out after committing my 'master' (where the need
changes for gdal 2.* have been made - was a September version of release-2_16
branch) and am now building.
2 weeks ago I found:
test_provider_ogr_sqlite.py
where I was planning to add some tests.
Since the original version is now compiling against gdal 2.*, I will
attempt to write a test that when running against gdal 1.* should cause a
'symbol lookup error'.
Also to test the ogr autotest database 'spatialite_8_2' which contains more
than 1 geometry in the main table
- which for the present code should fail.
The 3rd test was to test if the kml file sent for bugreport 15168
(non-unique layer-name) can be read correctly.
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161018/cc2a1f35/attachment.html>
