[Qgis-developer] Add some postgresql PKI authentication tests to Travis
Matthias Kuhn
matthias at opengis.ch
Thu Oct 20 03:05:02 PDT 2016
On 10/20/2016 11:53 AM, Sandro Santilli wrote:
> Start using docker containers for build ?
> https://docs.travis-ci.com/user/docker/
> With docker based builds you could make the test-oriented system as you need
> it (all deps in, multiple postgresql versions, other services, multiple
> configs) and run the build and the tests in such custom system.
I think the main challenge for this is a persistent ccache strategy or
build times will be up to an hour again.
Matthias
