[Qgis-developer] Changing layer style also changes edit forms - is that on purpose?
Matthias Kuhn
matthias at opengis.ch
Thu Oct 20 08:36:34 PDT 2016
Hi Régis,
I think this is a side-effect of saving everything to QML.
In fact, the qml API should be improved so it's possible to selectively
save certain configuration options. Then other parts of the app - like
map themes (visibility presets) - can handle this better. And users
could even chose what to export / import from a style in the vector
layer properties GUI when saving/loading a qml file.
Matthias
On 10/20/2016 04:42 PM, Régis Haubourg wrote:
> Hi,
> I was puzzled loosing my drag and drop forms in a qgs project until I
> realize that switching from one l ayer style to another will also switch
> form.
> I'm on qgis 2.16.3.
> Is that made on purpose so that user can store many edit forms per layer?
> I'm not sure it is useful and it triggers caveats :
> - user thinks he looses it's form and that something is broken
> - designing an application with different styles or layer presets require
> to copy-paste form definition in qgs file by hand to make it available on
> all layer styles.
> Any opinion? Someone is using that really or should we fix it?
> Cheers
> Régis
> Régis Haubourg
> GIS administrator and project manager
> Administrateur de données géographiques et chef de projet SIG
> Agence de l'eau Adour-Garonne
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-layer-style-also-changes-edit-forms-is-that-on-purpose-tp5291726.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
