[Qgis-developer] About project.qgs file versions
Nathan Woodrow
madmanwoo at gmail.com
Tue Oct 25 14:07:09 PDT 2016
Are you sure you can't open it in older versions? I mix project versions a
far bit and never seem to have any issues. Some styling options etc might
not load right but it should still open at least.
On Tue, 25 Oct 2016 11:10 pm Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On 25-10-16 13:56, Matthias Kuhn wrote:
> > Hi
> >> Oh yes, it's true ! You are right. I tested. :(
> >> So I am asking: what is the reason why we did this ?
> >> What you call "feature" is a problem for all those who need to share
> >> data with users who have an older version of QGIS, for one reason or
> >> another.
> >> I am wrong ? What do you think ?
> >> Regards
> >> Geo
> > Nothing has been explicitly done to prevent it.
> > The "feature" is a warning which you can interpret as "It might or might
> > not work in your scenario. Before you rely on backporting projects in
> > production scenarios, test it carefully.".
> > Or test one version and stick to that within a project which is the
> > safest choice.
> > Changing this behavior would be a considerable additional amount of work
> > and slow down development of new features (and there would still be no
> > guarantee).
> To state it perhaps more explicitly, this is not a 'feature'. It is a
> 'consequence' of the development or improvements of features in QGIS.
> This is basically a choice that has between made to avoid spending too
> much time on making project (.qgs) files back-ward compatible, as
> explained by Matthias. This may indeed be a problem for users (it has
> been for me in the past). But QGIS does provide a clear warning that
> your project files may not be backward compatible, to help users to run
> into problems later. It would have been nice to have some form of
> backward compatibility, but I understand why this may not be feasible,
> and I am happy I am being warned in advance.
> > Regards
> > Matthias
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161025/b9fdbe68/attachment.html>
