[Qgis-developer] Using Eclipse for QGIS Python development Ubuntu 16.04 64-bit - how ?
gordon at shieldaig.com
Tue Oct 25 19:01:00 PDT 2016
Setting up PyQGIS Python interpreter. Eclipse - Oxygen, how do you add
hidden folders, when you cannot see them, using the Libraries tab - new
folder button?
If you understand great - I am on page 94 of Python Programming Cookbook
(2015) for those that don't follow.
From the QGIS Python Console for QGIS 2.16:
import sys
sys.path
['/usr/share/qgis/python/plugins/processing',
'/home/gordon/.qgis2/python/plugins/GeoCoding/libs',
'/usr/share/qgis/python', u'/home/gordon/.qgis2/python',
u'/home/gordon/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/home/gordon/.local/lib/python2.7/site-packages',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
u'/home/gordon/.qgis2//python',
'/home/gordon/.qgis2/python/plugins/gearthview/ext-libs',
'/home/gordon/.qgis2/python/plugins/lifemapperTools/LmShared',
'/home/gordon/.qgis2/python/plugins', '.']
qgis
<module 'qgis' from
'/usr/lib/python2.7/dist-packages/qgis/__init__.pyc'>
I was planning to Library - add New Folder
/home/gordon/.qgis/python/plugins but the tool does not allow selection
of .qgis
If this isn't the best way, how should it be done?
Thanks for any tips.
