[Qgis-developer] Processing takes a very long time to close the Options popup
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Oct 26 09:58:13 PDT 2016
> is that on master?
> I detected that and found out that the grass icon, being a SVG, was
> causing that delay, since it was loaded hundreds of times. Replacing
> how it got loaded seemed to fix the issue, but apparently not in all
> machines, so there might be more than that....
As far as I can see on recent releases this is fixed. I remember it
clearly and now on clean installations seems ok.
Cheers!
-- G --
