[Qgis-developer] Processing takes a very long time to close the Options popup
roy roy royroge at outlook.com
Wed Oct 26 10:04:45 PDT 2016
Il 26/10/2016 17:40, Victor Olaya ha scritto:
> is that on master?
> I detected that and found out that the grass icon, being a SVG, was
> causing that delay, since it was loaded hundreds of times
Hi, not shure if this can be related to this issue i found today
about SVG symbols Path:
http://hub.qgis.org/issues/15759
maybe you had hundreds of duplicated path(?)
