[Qgis-developer] Field mapper when pasting features
Neumann, Andreas
a.neumann at carto.net
Fri Oct 28 01:54:57 PDT 2016
Hi Arnaud,
This sounds like a very useful feature to have. A big +1!
Not sure if it requires a QEP - but it never hurts to do one. Perhaps
other people have more idea, once they see a description or mockup.
Thanks in advance!
Andreas
On 2016-10-27 17:52, Arnaud Morvan wrote:
> Hello QGIS devs,
> I want to add a field mapper dialog when pasting features to layers.
> For now when pasting features with attributes names that do not exists on the destination layer,
> those attributes values are lost.
> When clipboard fields and destination layer fields are not strictly the sames,
> In QGIS 3.0, I want to popup a new dialog with fields mapper configurator.
> Dialog UI could be similar to Refactor Fields Algorithm, showing a list of destination fields :
> source expression (expression widgets) => destination field
> For example, I often use this workflow :
> Open a shapefile or autocad file.
> Use the refactor fields to get temporary layer with same fields as destination.
> Paste to postgis database layer.
> I think having this dialog showing up when needed could really ease data manipulation from one layer to another.
> And I want to give the possibility to use expressions.
> Any remarks, do you think I need to open to open a QEP for that ?
> Regards
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161028/85c0db8f/attachment.html>
