[Qgis-developer] Field mapper when pasting features
Neumann, Andreas a.neumann at carto.net
Fri Oct 28 03:59:12 PDT 2016
exactly. There are more situations where attributes need to be
harmonized between two different schemas.
It would be great if something generic could be developed that can be
re-used in other situations.
With that in mind - perhaps a QEP makes sense.
Andreas
On 2016-10-28 12:54, Richard Duivenvoorde wrote:
> Yep, both good ideas :-)
> One thing I think of: a 'mapper'-dialog could maybe also be used in the
> some algorithms like an 'union between 2 layers' and other algorithms
> which handle 2 or more feature types etc etc
> Regards,
> On 28-10-16 10:54, Neumann, Andreas wrote: Hi Arnaud,
> This sounds like a very useful feature to have. A big +1!
> Not sure if it requires a QEP - but it never hurts to do one. Perhaps
> other people have more idea, once they see a description or mockup.
> Thanks in advance!
> Andreas
> On 2016-10-27 17:52, Arnaud Morvan wrote:
> Hello QGIS devs,
> I want to add a field mapper dialog when pasting features to layers.
> For now when pasting features with attributes names that do not exists
> on the destination layer,
> those attributes values are lost.
> When clipboard fields and destination layer fields are not strictly
> the sames,
> In QGIS 3.0, I want to popup a new dialog with fields mapper configurator.
> Dialog UI could be similar to Refactor Fields Algorithm, showing a
> list of destination fields :
> source expression (expression widgets) => destination field
> For example, I often use this workflow :
> Open a shapefile or autocad file.
> Use the refactor fields to get temporary layer with same fields as
> destination.
> Paste to postgis database layer.
> I think having this dialog showing up when needed could really ease
> data manipulation from one layer to another.
> And I want to give the possibility to use expressions.
> Any remarks, do you think I need to open to open a QEP for that ?
> Regards
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161028/9399d7ac/attachment.html>
