[Qgis-developer] Raster/Projections/Assign Projection should use gdal_edit (not gdalwarp)
Agustin Lobo
alobolistas at gmail.com
Sun Oct 30 03:58:20 PDT 2016
As far as I understand, "Raster/Projections/Assign Projection" is meant
to change a wrong projection information in a raster layer, because the
real reprojection is done with Raster/Projections/warp
Nevertheless, "Raster/Projections/Assign Projection" uses gdalwarp, which
would actually reproject the layer. To just edit the projection information
I understand that "Raster/Projections/Assign Projection" should be
using gdal_edit.py
Am I wrong or is this a bug?
Agus
