[Qgis-developer] Visualisation of relations
Matthias Kuhn
matthias at opengis.ch
Mon Oct 31 02:06:20 PDT 2016
Hi Patrick,
for the side that contains the foreign key, there is the "relation
reference" widget which has a configuration option "show embedded form"
(I haven't used it in years and a quick check on it didn't work, so
maybe it needs fixing).
Agreed, collapsed by default makes sense for huge models. For small ones
it's a bit strange though. Another approach would be to put them on
separate tabs by default, I think that could look quite nice also. What
do you think?
Regards
Matthias
On 10/31/2016 09:54 AM, Patrick Valsecchi wrote:
> Hi Matthias,
> My screenshot shows only 1:N links. N:1 links are not supported. By N:1,
> I mean the relations from the side that contains the foreign key. If I
> open the form for the "appart" layer, it doesn't show the linked "maison".
> Yes, the collapsed state is remembered, but the default should be
> collapsed. If the default is to open everything, the GUI is going to
> explode if we have hundreds of linked tables.
> Thanks and CU.
> On Sun, Oct 16, 2016 at 8:57 AM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Hi Patrick,
> Making forms and relations more usable is always welcome.
> What exactly are the problems you have with the current solution?
> I see that you mentioned the lack of the N:1 side which is available
> including add feature, add link, remove feature, remove link pretty much
> the way you describe it. On [1] there is some explanation I wrote on the
> first implementation.
> I think you should have found that since it's shown on the screenshot
> which is attached to your mail.
> Also lazy loading (load when first visible) was introduced once for
> performance reasons and the collapsed state of the group boxes
> containing the QgsRelationEditor widget is remembered.
> So I think that functionality-wise, most of it should be there already.
> With a lot of air left for improvement on the usability side.
> Cheers
> Matthias
> [1] http://blog.vitu.ch/10112013-1201/qgis-relations
> <http://blog.vitu.ch/10112013-1201/qgis-relations>
> On 10/07/2016 09:27 AM, Patrick Valsecchi wrote:
> > Hi,
> > I'm tasked with making QGIS a bit more usable with complex database
> > schemas having a lot of relations (up to hundreds of linked tables). The
> > INSPIRE people were a bit too inspired when creating their data schemas
> > and now we have to try to make QGIS able to cope with that.
> > My concerns with the current situation (as of QGIS master) are:
> > * We can specify the relations between the layers at the project
> level
> > (it's now easier with the auto-discover feature for PostGIS and
> > Spatialite). But those are only showing in the QgsAttributeForm for
> > the 1-N side (the side that doesn't have the foreign key). Why not
> > on the N-1 side?
> > * For showing the N-1 side in the QgsAttributeForm, one can define a
> > Join in the layer's properties, but I don't see the point of having
> > to define it here as well when we have already the relations info at
> > the project level. I see a use for special joins, but for relations,
> > I don't see why we have to define it twice. And the way it's
> > displayed is not allowing to create joins or edit the joined fields.
> > * I let you imagine the look of the feature attribute form when
> there
> > are hundreds of directly and indirectly linked tabled. This is just
> > not usable if we display all of them directly like that. Just look
> > at the attached screen shot that shows what happens by default with
> > only 3 tables. It's already a mess.
> > Now, what I propose is:
> > * Not expand the relation widget (QgsCollapsibleGroupBox) by default
> > and build it's content only when it is expanded the first time
> > (think of what would happen when you have loops in the schema).
> > * Show N-1 relations as well, in a collapsed by default
> > QgsCollapsibleGroupBox, including a way to add a new linked entry,
> > remove the link (put the FK to NULL) and delete it.
> > * Add a button to open a related feature in a new window.
> > What do you guys think?
> > Thanks.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
