[Qgis-developer] Feedback for contrast enhancement ... enhancements ?
Even Rouault even.rouault at spatialys.com
Fri Sep 2 03:38:20 PDT 2016
There has been interest expressed to improve the usability of the contrast
enhancement function. Basically there are workflows where you want the min/max
values used by contrast enhancement to be updated each time you pan or zoom
the canvas. From what I've seen, here's what currently exists:
- a long method (6 clicks): through the Style tab of the layer properties
- a faster method (2 clicks): through the "Strech using current extent" of the
contextual menu of the layer panel.
When you have several rasters loaded, even the 2-click method is inconvenient,
so there's a need for a 0-click solution (once the layers have been configured)
Another shortcoming in the current implementation is that the settings of the
"Load min/max values" foldable group are not persistant, which requires re-
setting them if you're not happy with the default Cumlative count cut method.
And if you use the "Strech using current extent" menu item, the genuine
min/max values are used (not the 2-98% cumulative count cut)
So I was thinking to something along the following lines:
- make the min/max settings persistant
- remove the "Load" button and "Clip extent to canvas" checkbox, and replace
them by 3 radio buttons to determine the scope of statistics : "Whole raster",
"Current canvas" and "Updated canvas". See the attached proposal_min_max.png.
The function of the Load button would be replaced by the general Apply / OK
buttons.
- when the user manually enters the min/max values, the 2 groups of radio
buttons (method to compute min/max and scope of statistics) would be unchecked
so that is is clear that they don't come from computed statistics. I also
think that when you select "Current canvas", once the Apply/OK buttons have
been pushed, the checked state of Current canvas shouldn't be saved. This way
when you display the layer properties you have a good idea of where the
current min/max values come from.
- make the "Strech using current extent" method honour the way min/max are
computed in the min/max settings instead of using systematically the min/max.
So when "Updated canvas" would be selected, it would have no (extra) effect as
expected.
Any opinions ?
Even
http://www.spatialys.com
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/d04231ed/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/d04231ed/attachment-0003.png>
