[Qgis-developer] Processing qgis:joinattributesbylocation output empty if run from console
Anita Graser
anitagraser at gmx.at
Mon Sep 5 10:25:58 PDT 2016
qgis:joinattributesbylocation seems to produce correct output when run from
GUI but empty output when called from the console (just copied the command
from history):
processing.runalg("qgis:joinattributesbylocation","D:/Documents/Geodata/qgis_sample_data/shapefiles/popp.shp","D:/Documents/Geodata/qgis_sample_data/shapefiles/regions.shp","['within']",0,0,"sum,mean,min,max,median",0,None)
It also runs much faster on the command line, indicating that it's not
actually processing the data (because it's much slower through the GUI).
Can anyone reproduce? I use OSGeo4W version 2.16.
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160905/2953da6e/attachment.html>
