[Qgis-developer] Processing qgis:joinattributesbylocation output empty if run from console
Anita Graser anitagraser at gmx.at
Thu Sep 8 11:57:45 PDT 2016
On Thu, Sep 8, 2016 at 7:48 PM, Arnaud Morvan <arnaud.morvan at camptocamp.com>
wrote:
> Should be fixed with https://github.com/qgis/QGIS/pull/3471
> only remove double quotes around "['within']" => ['within'] and it works
Thanks Arnaud, I'll try that.
Best wishes,
Anita
> Arnaud Morvan
> Ingénieur logiciel
> Tél: +33 (0)4 58 48 20 32
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac Cedexhttp://www.camptocamp.com
> Le 05/09/2016 19:25, Anita Graser a écrit :
> Hi,
> qgis:joinattributesbylocation seems to produce correct output when run
> from GUI but empty output when called from the console (just copied the
> command from history):
> processing.runalg("qgis:joinattributesbylocation","D:/
> Documents/Geodata/qgis_sample_data/shapefiles/popp.shp","D:/
> Documents/Geodata/qgis_sample_data/shapefiles/regions.shp","
> ['within']",0,0,"sum,mean,min,max,median",0,None)
> It also runs much faster on the command line, indicating that it's not
> actually processing the data (because it's much slower through the GUI).
> Can anyone reproduce? I use OSGeo4W version 2.16.
> Best wishes,
> Anita
> Qgis-developer mailing listQgis-developer at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160908/83d088a4/attachment-0001.html>
