[Qgis-developer] [Qgis-user] Qgis nightly - stuck in loading "Add raster" dialog
Richard Duivenvoorde
rdmailings at duif.net
Fri Sep 9 07:24:09 PDT 2016
On 09-09-16 16:11, Amedeo Fadini wrote:
> hi everybody,
> I'm not subscribed the dev list, so I try posting here.
> Maybe is a know issue and will be fixed tonight.
> Just updated qgis from debian-nightly
> http://qgis.org/debian-nightly
> when I try to add raster it freezes trying to open the add raster dialog...
> The console output says
> src/gui/qgisgui.cpp: 38: (openFilesRememberingFilter) [6691ms] Opening
> file dialog with filters: All files (*);....
[moving to dev list]
Mmm, confirmed here: running a fresh compile of this morning (Debian
Jessie)...
Only when opening the Raster dialog
Running in gdb:
src/gui/qgisgui.cpp: 38: (openFilesRememberingFilter) [1607ms] Opening
file dialog with filters: All files (*);;GDAL/OGR VSIFileHandler (*.zip
*.gz *.tar *.tar.gz *.tgz *.ZIP *.GZ *.TAR *.TAR.GZ *.TGZ);;ACE2 (*.ace2
*.ACE2);;ARC Digitized Raster Graphics (*.gen *.GEN);;ASCII Gridded XYZ
(*.xyz *.XYZ);;Arc/Info ASCII Grid (*.asc *.ASC);;Arc/Info Binary Grid
(hdr.adf HDR.ADF);;Arc/Info Export E00 GRID (*.e00 *.E00);;DRDC COASP
SAR Processor Raster (*.hdr *.HDR);;DTED Elevation Raster (*.dt0 *.dt1
*.dt2 *.DT0 *.DT1 *.DT2);;ECRG TOC format (*.xml *.XML);;ESRI .hdr
Labelled (*.bil *.BIL);;EUMETSAT Archive native (*.nat *.NAT);;Envisat
Image Format (*.n1 *.N1);;Erdas Imagine Images (*.img *.IMG);;FARSITE
v.4 Landscape File (*.lcp *.LCP);;GMT NetCDF Grid Format (*.nc
*.NC);;GRIdded Binary (*.grb *.GRB);;GeoPackage (*.gpkg
*.GPKG);;GeoSoft Grid Exchange Format (*.gxf *.GXF);;GeoTIFF (*.tif
*.tiff *.TIF *.TIFF);;Geospatial PDF (*.pdf *.PDF);;Golden Software 7
Binary Grid (*.grd *.GRD);;Golden Software ASCII Grid (*.grd
*.GRD);;Golden Software Binary Grid (*.grd *.GRD);;Graphics Interchange
*.GIF);;Ground-based SAR Applications Testbed File Format (*.gff
*.GFF);;HF2/HFZ heightfield raster (*.hf2 *.HF2);;Hierarchical Data
Format Release 4 (*.hdf *.HDF);;Hierarchical Data Format Release 5
(*.hdf5 *.HDF5);;ILWIS Raster Map (*.mpr *.mpl *.MPR *.MPL);;IRIS data
*.JPG *.JPEG);;JPEG-2000 driver based on OpenJPEG library (*.jp2 *.j2k
*.JP2 *.J2K);;Japanese DEM (*.mem *.MEM);;KOLOR Raw (*.kro
*.KRO);;Leveller heightfield (*.ter *.TER);;MBTiles (*.mbtiles
*.MBTILES);;MS Windows Device Independent Bitmap (*.bmp *.BMP);;Magellan
topo (*.blx *.BLX);;NOAA NGS Geoid Height Grids (*.bin *.BIN);;NOAA
Vertical Datum .GTX (*.gtx *.GTX);;NTv2 Datum Grid Shift (*.gsb
*.GSB);;National Imagery Transmission Format (*.ntf *.NTF);;Network
Common Data Format (*.nc *.NC);;Northwood Classified Grid Format
.grc/.tab (*.grc *.GRC);;Northwood Numeric Grid Format .grd/.tab (*.grd
*.GRD);;PCIDSK Database File (*.pix *.PIX);;PCRaster Raster File (*.map
*.MAP);;Portable Network Graphics (*.png *.PNG);;Portable Pixmap Format
(*.pnm *.PNM);;R Object Data Store (*.rda *.RDA);;Raster Matrix Format
(*.rsw *.RSW);;Raster Product Format TOC format (*.toc
*.TOC);;Rasterlite (*.sqlite *.SQLITE);;SAGA GIS Binary Grid (*.sdat
*.SDAT);;SDTS Raster (*.ddf *.DDF);;SGI Image File Format 1.0 (*.rgb
*.RGB);;SRTMHGT File Format (*.hgt *.HGT);;Snow Data Assimilation System
(*.hdr *.HDR);;Standard Raster Product (*.img *.IMG);;Swedish Grid RIK
(*.rik *.RIK);;Terragen heightfield (*.ter *.TER);;USGS Optional ASCII
DEM (*.dem *.DEM);;VTP .bt (Binary Terrain) 1.3 Format (*.bt
*.BT);;Vexcel MFF Raster (*.hdr *.HDR);;Virtual Raster (*.vrt *.ovr
*.VRT *.OVR);;WEBP (*.webp *.WEBP);;X11 PixMap Format (*.xpm
*.XPM);;ZMap Plus Grid (*.dat *.DAT)
[New Thread 0x7fff2bfff700 (LWP 8139)]
[New Thread 0x7fff2b7fe700 (LWP 8140)]
[New Thread 0x7fff2affd700 (LWP 8141)]
src/core/qgsbrowsermodel.cpp: 418: (itemStateChanged) [145ms] item
pg:/richard at localhost.gis state changed 1 -> 2
src/gui/qgsmapcanvas.cpp: 704: (refreshMap) [2ms] CANVAS refresh!
src/core/qgsscalecalculator.cpp: 40: (setMapUnits) [1ms] Map units set to 2
src/core/qgsmaprendererparalleljob.cpp: 87: (start) [0ms] QThreadPool
max thread count is 2
src/core/layertree/qgslayertreemodel.cpp: 1471:
(invalidateLegendMapBasedData) [2ms] Entering.
(invalidateLegendMapBasedData) [0ms] Leaving.
src/core/qgsmaprendererparalleljob.cpp: 201: (renderLayersFinished)
[12ms] PARALLEL layers finished
src/core/qgsmaprenderercustompainterjob.cpp: 292: (drawLabeling) [1ms]
[thread:0xac213d0] Draw labeling start
src/core/qgsmaprenderercustompainterjob.cpp: 320: (drawLabeling) [0ms]
[thread:0xac213d0] Draw labeling took (seconds): 0
src/core/qgsmaprendererparalleljob.cpp: 221: (renderingFinished) [25ms]
PARALLEL finished
src/gui/qgsmapcanvas.cpp: 751: (rendererJobFinished) [0ms] CANVAS finish! 1
[New Thread 0x7fff2a188700 (LWP 8142)]
[Thread 0x7fff2a188700 (LWP 8142) exited]
[Thread 0x7fff2affd700 (LWP 8141) exited]
[Thread 0x7fff2b7fe700 (LWP 8140) exited]
[Thread 0x7fff2bfff700 (LWP 8139) exited]
[Thread 0x7fff43fff700 (LWP 8104) exited]
[Thread 0x7fff3ac79700 (LWP 8114) exited]
[Thread 0x7fff48ede700 (LWP 8113) exited]
[New Thread 0x7fff48ede700 (LWP 8144)]
[New Thread 0x7fff3ac79700 (LWP 8145)]
[Thread 0x7fff48ede700 (LWP 8144) exited]
[Thread 0x7fff3ac79700 (LWP 8145) exited]
[New Thread 0x7fff3ac79700 (LWP 8168)]
looks like it is stuck in opening new threads?
Regards,
Richard
