[Qgis-developer] Qgis donload entire postgis data table (with geom?) opening attribute table
Pietro Rossin
pierigis at gmail.com
Tue Sep 13 05:19:02 PDT 2016
Hello
with Qgis and Postgis layers I noticed a strange behaviour
Qgis 2.16.2 on windows 7 x64, Postgis 2.1 on Postgres 9.4.x debian server
I created a vector multipolygon table:
CREATE TABLE myschema.mytable
( id serial NOT NULL,
geom geometry(MultiPolygon,3045),
name character varying(254),
code character varying(254),
CONSTRAINT mytable_pkey PRIMARY KEY (id)
WITH (
OIDS=FALSE
CREATE INDEX sidx_mytable_geom
ON myschema.mytable
USING gist
(geom);
This table contains 217 feature (regional districts) with names and codes.
Disk space (https://wiki.postgresql.org/wiki/Disk_Usage) is:
oid 17848
table_schema = myschema
table_name = mytable
row_estimate = 217
total_bytes = 22142976
index_bytes = 24576
toast_bytes = 22077440
table_bytes = 40960
total = 21 MB
index = 24 kB
toast = 21 MB
table = 40 kB
When I load this layer in TOC Qgis downloads 1.3MB (server side
simplyfication enabled in display options).
Then If I right click on layer and select open attribute table Qgis
downloads 22MB.
Then on the table if I click on the top left corner to select all records
Qgis downloads other 1.3MB.
At this point If I copy (ctrl+C) all records Qgis downloads other 22MB.
Pasting into excel spreadsheet result in a huge amount of data, because
there is a WKT column with geometry in WKT format.
Executing this query
SELECT id, name, code FROM mytable;
in Qgis generates 9.0KB download traffic
PGAdminIII generates 9.9KB with the same query.
In PGadminIII this query
SELECT id, ST_AsEWKt(geom), name, code FROM myschema.mytable;
or this one
SELECT id, ST_Astext(geom), name, code FROM myschema.mytable;
downloads 45.8MB
It seems that Qgis downloads some kind of geometry definition opening
attribute table, it doesn't seem a wkt (22MB vs 45.8MB)
Now,
is this normal??
If yes, what is the usefulness in downloading all postgis/postgres table
when selecting "open attribute table"?
Couldn't be more useful to download only real "attribute values", 9KB
instead of 22MB??
I know in previous Qgis version there was the possibility to choose if we
wanted the WKT column together with attribute table for copy/paste from/to
other applicatios, in Qgis 2.16 I kan't find it..
Thanks
Pietro
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-donload-entire-postgis-data-table-with-geom-opening-attribute-table-tp5285532.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
