[Qgis-developer] Couldn't load plugin fTools
Alexander Bruy
alexander.bruy at gmail.com
Tue Sep 13 05:40:03 PDT 2016
Seems you trying to install QGIS master on the top of existing QGIS
installation without removing old files. fTools plugin was removed in
QGIS 2.16.
Please perform clean install (remove all old files first)
2016-09-13 15:07 GMT+03:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi all,
> I just compiled without error qgis master 2.99.0-master d265f33 on ubuntu
> 16.04.
> However I got this error on launching the application:
> Couldn't load plugin fTools due to an error when calling its classFactory()
> method
> ImportError: cannot import name QGis
> Traceback (most recent call last):
> File "/usr/local/share/qgis/python/qgis/utils.py", line 333, in
> startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "/usr/local/share/qgis/python/plugins/fTools/__init__.py", line 33,
> in classFactory
> from .fTools import fToolsPlugin
> File "/usr/local/share/qgis/python/qgis/utils.py", line 642, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/usr/local/share/qgis/python/plugins/fTools/fTools.py", line 33, in
> from qgis.core import QGis
> Python version: 2.7.12 (default, Jul 1 2016, 15:12:24) [GCC 5.4.0 20160609]
> QGIS version: 2.99.0-Master Master, d265f33
> Python Path:
> /usr/local/share/qgis/python/plugins/processing
> /home/eugenio/.qgis-dev//python
> /home/eugenio/.qgis-dev//python/plugins
> /usr/lib/python2.7
> /usr/lib/python2.7/plat-x86_64-linux-gnu
> /usr/lib/python2.7/lib-tk
> /usr/lib/python2.7/lib-old
> /usr/lib/python2.7/lib-dynload
> /usr/local/lib/python2.7/dist-packages
> /usr/lib/python2.7/dist-packages
> /usr/lib/python2.7/dist-packages/PILcompat
> /usr/lib/python2.7/dist-packages/gtk-2.0
> /usr/lib/python2.7/dist-packages/ubuntu-sso-client
> /usr/lib/python2.7/dist-packages/wx-3.0-gtk2
> After that qgis start normally, but all the python plugin were not loaded.
> Any hints on this regard?
> Eugenio
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
