[Qgis-developer] Couldn't load plugin fTools
    Arnaud Morvan
    arnaud.morvan at camptocamp.com
    Tue Sep 13 07:04:21 PDT 2016
Apparently the release of the plugin is not be compatible with QGIS master,
which is not surprising as API breaks are allowed on master branch for
QGIS 3.0.
Here is some hints to work with QGIS master :
     * do not install QGIS master system wide, better install it in your
home directory.
     * QGIS master use plugins from in $HOME/.qgis-dev/python/plugins
directory
         so you could clone the plugin master branch, build it if
necessary and install it to $HOME/.qgis-dev/python/plugins directory
         and propose pull request on the plugin repo if suitable
Hope this helps.
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 13/09/2016 15:44, Eugenio Trumpy a écrit :
> Before make install command I remove qgis dir from /usr/local/share,
> after make install (now without error) qgis runs correctly, but I have
> not any plugin.
> So I started to reinstall those important for me...someone (e.g
> lizmap) gave me this message in the error box:
> The plugin is broken. Python said:
> global name 'Qgis' is not defined
> hints?
> E.
> *Da:* Alexander Bruy <alexander.bruy at gmail.com>
> *Inviato:* martedì 13 settembre 2016 15.12
> *A:* Eugenio Trumpy
> *Cc:* qgis-developer at lists.osgeo.org
> *Oggetto:* Re: [Qgis-developer] Couldn't load plugin fTools
> I was talking about *installation* directory, not repo.
> 2016-09-13 16:05 GMT+03:00 Eugenio Trumpy <frippe12573 at hotmail.com
> <mailto:frippe12573 at hotmail.com>>:
>     Hi Alexander,
>     I just clone newly the qgis repo, I started from scratch.
>     What kind of old file do you mean?
>     E.
>     <mailto:alexander.bruy at gmail.com>>
>     *Inviato:* martedì 13 settembre 2016 14.40
>     *A:* Eugenio Trumpy
>     <mailto:qgis-developer at lists.osgeo.org>
>     Seems you trying to install QGIS master on the top of existing QGIS
>     installation without removing old files. fTools plugin was removed in
>     QGIS 2.16.
>     Please perform clean install (remove all old files first)
>     2016-09-13 15:07 GMT+03:00 Eugenio Trumpy <frippe12573 at hotmail.com
>     > Hi all,
>     > I just compiled without error qgis master  2.99.0-master d265f33
>     on ubuntu
>     > 16.04.
>     > However I got this error on launching the application:
>     > Couldn't load plugin fTools due to an error when calling its
>     classFactory()
>     > method
>     > ImportError: cannot import name QGis
>     > Traceback (most recent call last):
>     >   File "/usr/local/share/qgis/python/qgis/utils.py", line 333, in
>     > startPlugin
>     >     plugins[packageName] = package.classFactory(iface)
>     >   File
>     "/usr/local/share/qgis/python/plugins/fTools/__init__.py", line 33,
>     > in classFactory
>     >     from .fTools import fToolsPlugin
>     >   File "/usr/local/share/qgis/python/qgis/utils.py", line 642,
>     in _import
>     >     mod = _builtin_import(name, globals, locals, fromlist, level)
>     >   File "/usr/local/share/qgis/python/plugins/fTools/fTools.py",
>     line 33, in
>     >     from qgis.core import QGis
>     > Python version: 2.7.12 (default, Jul  1 2016, 15:12:24) [GCC
>     5.4.0 20160609]
>     > QGIS version: 2.99.0-Master Master, d265f33
>     > Python Path:
>     > /usr/local/share/qgis/python/plugins/processing
>     > /home/eugenio/.qgis-dev//python
>     > /home/eugenio/.qgis-dev//python/plugins
>     > /usr/lib/python2.7
>     > /usr/lib/python2.7/plat-x86_64-linux-gnu
>     > /usr/lib/python2.7/lib-tk
>     > /usr/lib/python2.7/lib-old
>     > /usr/lib/python2.7/lib-dynload
>     > /usr/local/lib/python2.7/dist-packages
>     > /usr/lib/python2.7/dist-packages
>     > /usr/lib/python2.7/dist-packages/PILcompat
>     > /usr/lib/python2.7/dist-packages/gtk-2.0
>     > /usr/lib/python2.7/dist-packages/ubuntu-sso-client
>     > /usr/lib/python2.7/dist-packages/wx-3.0-gtk2
>     > After that qgis start normally, but all the python plugin were
>     not loaded.
>     > Any hints on this regard?
>     > Eugenio
>     > _______________________________________________
>     > Qgis-developer mailing list
>     > Qgis-developer at lists.osgeo.org
>     <mailto:Qgis-developer at lists.osgeo.org>
>     > List info:
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Qgis-developer Info Page - lists.osgeo.org Mailing Lists
>     lists.osgeo.org <http://lists.osgeo.org>
>     Discussion of all things QGIS development related. To see the
>     collection of prior postings to the list, visit the Qgis-developer
>     Archives.
>     > Unsubscribe:
>     Alexander Bruy
> Alexander Bruy
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160913/067f1c11/attachment.html>
