[Qgis-developer] Additional TIFF RASTER Problems
C Hamilton adenaculture at gmail.com
Wed Sep 14 06:26:53 PDT 2016
There have been a lot of Raster issues mentioned with 2.16 lately and in
the case of Windows it has been associated with the 32-bit install.
There are also problems with the 64-bit install as well, but is not as
obvious. This test in using the 64-bit OSGeo4W network installer and
applies to 2.16.2.
If you open the "OSGeo4W" command shell and run gdalinfo on any TIFF image
you get a crash message saying:
"gdalinfo.exe has stopped working"
It gets partway though displaying the tiff information and shows the image
width and height but then it crashes. Interestingly, if you try this
with"OSGeo4W Shell" it seems to work. I am now sure what the difference is
between the two.
Do any of you get the same results?
Thanks,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160914/b61fbaf5/attachment.html>
