[Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
Nyall Dawson
nyall.dawson at gmail.com
Thu Sep 15 23:31:58 PDT 2016
On 16 September 2016 at 16:16, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi Nyall,
> I have been using 2.16 in a 3 week summer class. We have been using these functions, and not seen the described errors.
> We use OS : Windows 7 and 8 - the MAC users was using 2.14
> Is it on Linux you get the errors ?
No - it's on Windows. And I can't reproduce it everytime, but it has
happened multiple times.
Nyall
> Regards
> Lene Fischer
> -----Oprindelig meddelelse-----
> Fra: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne af Nyall Dawson
> Sendt: 16. september 2016 03:09
> Til: qgis-developer
> Emne: [Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
> Unfortunately a fairly nasty regression has slipped in to 2.16 and is still present on master. This results in shapefile corruption in certain circumstances.
> While I've hit this issue maybe 3 or 4 times in the last 2 months, I haven't been able to track down exactly what causes this. It seems related to using the split or reshape tool on a shapefile, then saving the changes and getting the errors "Cannot reopen datasource
> xxx.shp|layerid=0 in read-only mode" and "Data source is invalid (Unable to open xxx.shx or xxx.SHX.Try --config SHAPE_RESTORE_SHX true to restore or create it)" in the log.
> A full report is at http://hub.qgis.org/issues/15570
> Hopefully we can resolve this before the next round of releases. In the meantime, there's a workaround for recovering data:
> In the same folder as the shapefile there'll be additional files "xxx_packed.shp" and "xxx_packed.shx". Renaming the "xxx_packed.shx"
> file to "xxx.shx" allows the original shapefile to be reopened.
> Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
